cam specs
I'm pretty sure that thats pushin it for a 5.4L, if you do get it, make sure you get the 4.10 gears.
Its hard to say. I would say get the V10 because it would be great for power when driving around, and would do a better job at that hill. It wouldn't do too hot on the gas though. I don't think it would be that much worse than the 5.4L considering the efficiency of these new motors...
Originally Posted by 864x2mudder
If I were you I would go with the 6.0 powerstroke diesel. Good gas mileage and diesel is cheaper than gas now. Plus it will pull anything.
BTW, how did this thread go from cam specs to which engine do I need?
take it from me...a friend had a v-10...couldn't change the back two spark plugs...some tool that can only be rented FROM snap-on TO a mechanic to do it, and it's a pain anyway...also...diesel up here is NOT cheaper than regular (87 octane) gasoline...it's about 5 cents more expensive...just somethin to throw out there...
MontanaFord
MontanaFord
Originally Posted by Keith Bauman
I want to to a 7000 lb trailer out of my driveway at 30 deg angle,.
I've had two 5.8 F250's with 3.55 ratio, they were fine. Remember, the 92 5.8 has 60 less hp then the current 5.4. My '92 Auto would run 17.3 1/4 mile.
It's not like you're racing someone out there.
If you're getting a 4x4, then, you can always use low range for that 30 deg. incline driveway.
FEmtnmax
10-18-2005 04:56 AM
