What is involved?
Old Apr 9, 2004 | 04:27 AM
whcf150's Avatar
whcf150
Lightbulb What is involved?
I would like to install a 240 cu in engine into a 64 Ranchero, It has a 170 at present. I have a complete 240 from a Fairmont (1982). Any help will be greatly welcomed. Oh, The 240 will be warmed a little with a cam , carb. and headers. Thanks Bill
Old Apr 9, 2004 | 08:51 AM
jessfactor's Avatar
jessfactor
there's an engine swap forum
https://www.ford-trucks.com/forums/f...play.php?f=136
and a ranchero forum
https://www.ford-trucks.com/forums/f...splay.php?f=43
you'll probably get more input over there.
Old Apr 9, 2004 | 09:08 AM
oldhalftons's Avatar
oldhalftons
you DON'T have a 240 from a 82 fairmont, most likely is a 200 or 250
240 prduction ended in 72.
the easiest way to tell a 240/300 from a 170/200/250 is the 240/300 has a valve cover with 6 large indents on the carb side. the small sixes have several small indents on the side of the cover.
there is lots of ID info on the smallblock sixes over at www.fordsix.com
Old Apr 9, 2004 | 09:42 AM
whcf150's Avatar
whcf150
oldhalfton, I guess what I need then is the 240/300 engine. Maybe the air cleaner has been change in this Fairmount. I rechecked and decal says 250. But you are correct. The valve cover is exactly like my 86 150. I think I need to start looking for correct engine. Thanks for the info at the web site. Thanks Bill
