1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Brake Question
Old 04-01-2004, 07:05 PM
khmorse's Avatar
khmorse
khmorse is offline
Brake Question
I recently changed the rotors and pads on my truck. Now, I have a squeal when stopping at slower speeds. After replacing the brakes, on another weekend I replaced the shocks. While I had the tires off, I pulled the brakes off, put some stop squeal on the back of the pads, and made sure everything was seated right. Also ran some sand paper over the pads/rotors. The brakes stop nicely, certainly better than before I changed them. But, I cannot get rid of the squeal. It drives me nuts. I feel like I am driving some type of beater when I pull up next to people w/my brakes squealing.
Old 04-02-2004, 06:31 AM
khmorse's Avatar
khmorse
khmorse is offline
Hey guys, help me out here. What should I try to make the squeal stop? You guys always some tidbit of advice for everything.
Old 04-02-2004, 09:34 AM
buzzard's Avatar
buzzard
buzzard is offline
I had the same problem a while back and it took new rotors and pads to correct.
I replaced my front pads, oh a year or so ago, without removing the rotors. Everything was perfect until a shop replaced my lower ball joints. In doing so, they removed the front rotors and replaced upon completion of the job. Almost immediately thereafter the front brakes squealed like nothing I'd ever heard. I took the pads off and smeared some anti-rattle compound on the backs of the pads. That didn't work. I took the pads off again and sanded them and the rotors. That didn't work. I finally took pads and rotors off and replaced the whole bunch.....luckily the old pads were replaced under warranty. Now I have quiet brakes.
What had happened was the pads somehow must not have re-seated properly after the shop reassembled. They were "skipping" along the rotors. This was very evident in viewing the pads at certain angles. I've read that if the pads are even fractionally off (not flat and properly seated to the rotors) they will squeak. The whole ordeal wound up costing me a few hours labor and the price of two new rotors, ~$45 each.
Hope this helps.
Old 04-02-2004, 01:07 PM
dalfollo's Avatar
dalfollo
dalfollo is offline
When installing brake pads, where exactly should the stop squeel be put...only where there is contact, or alover the back of the pad?
Old 04-02-2004, 03:02 PM
buzzard's Avatar
buzzard
buzzard is offline
The majority of the pad doesn't touch anything, thus there's no need for it to be "all over." That said, it doesn't hurt to smear over the whole back side. Be careful not to get it on the front of the pad.
Old 04-02-2004, 11:41 PM
BubbaP's Avatar
BubbaP
BubbaP is offline
khmorse- What brand pads are you using?
The only thing that stopped squealing brakes on my old GMC was to use the better Wagner brand (Thermo-Quiet, I think) from Oreilly's. I have used them on four other vehicles with good results- no squeaky brakes.
I replaced both front and rear pads on our Expedition about a month ago. The front pads were $54.99 and rear were $45.99.
Old 04-03-2004, 12:20 AM
buzzard's Avatar
buzzard
buzzard is offline
BubbaP, that's the pad I've been using....Wagner Thermoquiet.
Old 04-05-2004, 12:43 PM
khmorse's Avatar
khmorse
khmorse is offline
Thanks. Where do you buy these pads at?
Old 04-05-2004, 02:59 PM
buzzard's Avatar
buzzard
buzzard is offline
khmorse, I got mine at O'Reilly.
Old 04-05-2004, 04:11 PM
khmorse's Avatar
khmorse
khmorse is offline
Thanks Buzzard. Unfortunately, as per their website, there are not any O'Reilly's in Eastern VA. I went to the websites for Auto Zone, Advance Auto, Napa, Pep Boys, and CarQuest today. None of them carry these pads. Must not be that popular a brand. But, if they work, I'll keep looking.
Old 04-05-2004, 04:52 PM
tonum24's Avatar
tonum24
tonum24 is offline
If you come across Raybestos quiet stop (ceramic) get em. I can't say enough how they give a very smooth braking with negligeable dust and never squeeked once in 35,000 miles on my first set. I'm on set #2.
Old 04-05-2004, 07:12 PM
khmorse's Avatar
khmorse
khmorse is offline
Thanks. I did see that Advance Auto and Napa both sell Raybestos pads.
Mike in PA
1999 to 2016 Super Duty
05-05-2014 07:21 PM
twall_SD250
06-24-2013 06:28 PM
abyars111
02-23-2012 10:28 PM
jcamp
05-27-2008 07:25 AM
SMc
07-11-2004 09:47 PM
Quick Reply: Brake Question
