Firestone Ride-Rite
I put them on me 2000 E150 conversion van. After doing the research, I found that Firestone and Air Lift are designed almost identical. The thing that made me choose the Firestone was the warranty. The Air Lift brand only gives you a 1 year warranty UNLESS you buy their compressor kit, then you get a better warranty. I did not want the compressor or the extra cost, so I bought the Firestone brand. Install was not that difficult. Make sure you have a sharp drill bit. I invested in two new ones for the job(the size I needed and a smaller bit for a pilot hole) and was glad I did.
i have the air-lift on my 1 ton ford cube van and after about 5 years one of them went bad. So i bought the same set, now one is leaking after about 5 years! So with air-lift and heavy duty use, 5 years is what to expect. My single axel van weight in at 10,400 and i use around 80 pis all the time...
I have Ride-Rites on the dually in my sig. I absolutely love them. In my opinion, adding air bags is the best mod you can do to a tow vehicle. I then put on a Viair 10007 system so I can adjust them on the fly, and air them down when not towing, from the cab. The "no-drill" kits are nice. Just take your time when installing them and they will go on fine. I have had no problems with mine.
Max100TN
Fifth Wheel & Gooseneck RV Towing
09-13-2014 03:38 PM
rtazz17
6.7L Power Stroke Diesel
18
09-04-2013 10:51 PM
