Firestone Ride-rites for my truck
I'm interested in buying a set of Firestone Ride-rites for my truck and I'm wondering which part number I should get?
My truck is a 2005 Ford F-250 CC/SB, FX4. I don't have an in-bed hitch, but I may add one later. I want a kit that I don't have to drill into the frame rails.
I've received conflicting responses from different vendors as to which part number I need, so I figured I'd ask here.
Thanks in advance.
Thanks in advance.
These are the ones that I am looking to put on mine; 57394 Air Lift LoadLifter 5000 Rear Air Spring Suspension Kit | Truckspring.com
I do want the Firestone airbags, I just want to make sure that they are a "drill-less" set for my 2005 F-250 CC/SB 4x4. If they accomodate an in-bed hitch, I'm okay with that because I may add one later. I just want to know the exact part number that will fit my truck so I'm not stuck with $300 worth of parts that don't work for me. Thanks again!
I ran into the same problem, firestone gave me the part number for 2008's and up, and I have a 2006. The part number I ordered was 2450 that firestone gave me. I ordered my from suspension connection. Not to hard to put on, took me about a half of day.
And yes you can add the on board compressor later, you would just maybe have to purchase extra air hose, depends on where you mount the compressor at. I do not see the need for it other then the convenience.
For my truck, I've seen 3 different numbers: 2400, 2071, and 2452. The website says 2452, but the Firestone rep says 2400, and the place I would like to purchase them from says 2071. Hence the confusion!
I just want someone to say: "I ordered part #XXXX and it installed perfectly with no drilling" and I will jump on it.
Here ia a copy and paste of the invoice.
Quan Item No. Description Price Extension
1 2450 2008-2009 Ford F250 / F350 $278.95 $278.95
(will fit with 5th wheel &
gooseneck trailers) -
Firestone "Ride-Rite" NO-DRILL
Air Bag Helper Springs (Rear)
This is from Suspension Connection, and I purchased then 5 months ago, they are now $309.95. You may shop around for a better price maybe.
But these fit my 2006 f250 with B&W Turnover ball hitch great!!! No Drilling at all!!!!
And to think that all I wanted was a straight answer for the part number for my truck and I would've bought these a week ago.
Let me see if I can un confuse this for you.
First the numbers
2400- Is for a truck w/o a in bed hitch
2071- Is for a truck w/o a hitch installs on top of the leaf springs
2452- Is for 2 wheel drive w/o a hitch
2400- Is for a truck w/o a hitch
2071- Installs on top of the leaf springs so it cannot be used with a turnover ball hitch
And there may be the problem, in your org post you said you may want a in bed hitch. There are allot of in bed hitchs out there, and some of these air bags will work with them. But none of these numbers here will work with a B&W turn over ball hitch, or other brand names of hitchs that have a turn over ball with the release handle coming out of the frame by the drivers side tire. So i think you need to be more specific on which hitch you are thinking about going with, ( Gooseneck, fifth wheel ). I like my B&W gooseneck and if I want a fifth wheel hitch I will just by the companion hitch. I would recomend the 2450 it mounts inside the frame rails so you can put any kind of hitch you want in your truck later. Hope this helps.
First the numbers
Order the Firestone 2400 kit. I put them on my 2006 F-350 with a Reese Signature Series 18K hitch. No interference between hitch and bag brackets. No drill.
I did have to pull the hitch plates off the sides of the frame by removing 4 bolts, but I left the hitch in the bed and the crossbars in place. After I got the bags installed, I put the plates back on with no problem - that added maybe 15 minutes per side to the job.
