What are the signs of bad u-joints?
Hello,
Just out of curiousity, what are the signs of bad universal joints? My truck is approaching 10 years of age with under 90,000 miles on it. Is it a normal scheduled maintenance item after a certain mileage (like a fuel filter)? I notice from time to time, the truck will shake when taking off in first gear. Other than that, the truck drives great.
Cheers,
Dan
Cheers,
Dan
the only thing i have owened that the u-joints went out on was my '73 mach I and they went out every 6 months or so, and i could tell when they were bad. i will try to explain this; when they were bad and you had pressure on the driveline(accelerating or deaccelerating) you could not tell, but if you "costed" the driveline in other words gave it enough gas to take any resistance off the driveline you could feel a vibration and when i felt that i knew my u-joints were bad.
There are greaseable and non-greaseable types. The only way to know if the joint needs to be replaced is if you get under the truck and grab the two yokes and try to move them around. Look for movement in the joint. I grease mine everytime I change the oil, water gets in there when it rains and wears them out. The joints will usually seem fine, and then all of a sudden eat themselves within a few thousand miles. Most of U-joint failures come from lack of lubrication.
you can always tell when they break..sorry couldn't resist. I have always noticed a "clicking" sound when they are getting bad. if you off-road, you should check them more often because of the extra stresses
oh yeah, and the u-joints for the front driveshaft are interchangeable, so if you ever break a rear one, just take one off the front to get you home
