replacing coil bolts 98 5.4l
Old 03-22-2004, 03:52 PM
troc99's Avatar
troc99
troc99 is offline
Its about time to replace the plugs but from what I've read, theres a chance the coil bolts can snap off. In case they ever need to come out again while I own this truck, I was thinking about replacing them with ether Stainless,brass or grade 8 bolts. I know some dissimilar metals can create corrosion so I just wanted other peoples opinions and recommendations on this.
Thanks
Old 03-23-2004, 04:02 AM
fitter565's Avatar
fitter565
fitter565 is offline
Use some sort of never seize when you re-install the bolts. And remember to reduce your torque by 30-40% after using a lube on the threads. Hope this helps!
Fitter
SQUIRMIN VERMIN
1997 - 2003 F150
06-24-2014 05:40 PM
460
Offroad & 4x4
12-16-2006 08:39 AM
troc99
03-22-2004 02:05 PM
bookem123
1997 - 2003 F150
02-26-2004 05:40 AM
Quick Reply: replacing coil bolts 98 5.4l
