how to take off fuel filter?
I just changed my fuel filter last night...it's a pain in the ***!! I think the trick to it is is to shoot some penetrating fluid up into the line so it will loosen up the spring inside the line. I sprayed PB Blaster in mine and worked it for about 10min. and it came off. My rear line came off real easy, the front one was a royal pain. Just keep working the line back and forth onto and off the fuel filter...it will come off eventually.
Thanks Luke_trash!! The ones you say works easily were exactly the ones I was eyeballing at lunch, as they appeared to also be used on my AC line fittings too, but wanted to find out more about them before spending anymore $$ than I already have. I would've emailed this message, but I'm not authorized to do so yet, having just joined today.
the first pic is the tool i got.. only cost me 5 bux.. and ya it didn't work to great at all either.... but then again i gave up after 5 minutes.. ill have to try wut drumguy said.. work it in with some lube.. i'll give it a shot this weekend just in case i break somethin don't gota find a ride to work tomorrow.. thanx again guys.. ill let ya no how it goes
After I got the tool set that Luke_Trash suggested the filter came off easily...... of course once I used the right size!!! I was trying the 5/16 and fought it for about 10 minutes then the lightbulb came on and grabbed the 3/8 tool and the connections released without much effort! Always have the right tools for the job!!! It sure makes being a shadetree mechanic a more pleasant experience! Thanks guys.
powerstroke 6.0
02-02-2008 12:37 AM
ItsATruckThing
1983 - 2012 Ranger & B-Series
02-29-2004 01:30 PM
