get out the propane torch dont light!! it but turn it on. then start the truck and run the propane torch any every posible place there might be a vacuum leak and listen for the engine to rev up when it revs up you have found the leak
the engine just burns the propane like it is regular fuel and it wont hurt the engine
if you cant get it to idel the propane idea wont work what year is the truck and is it efi? if it is check the idel bypass valve if that valve isnt operating properly then it wont idel at all
