Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Diesel noise Ford vs. Dodge
Old 03-19-2004, 10:03 AM
crazycanuck's Avatar
crazycanuck
crazycanuck is offline
I am in the process of deciding which truck to buy, either the F-350 diesel, or dodge 3500 diesel. Every salesman I ask tells me theirs is quieter.
Regarding the 2004 models, which is really quieter, both inside and outside the vehicle, and secondly, how does the 2004 really compare to previous years(noise wise).
Thanks
Crazycanuck.
Old 03-19-2004, 12:09 PM
aketay's Avatar
aketay
aketay is offline
If noise is all you are worried about, buy a Duramax.
Old 03-19-2004, 02:24 PM
MJD's Avatar
MJD
MJD is offline
They're both pretty quiet. I would advise trying each one out and seeing for yourself. The D-max is probably the most quiet diesel out there right now. I like a little noise and a good whistle from the turbo, myself. By the way, can anyone see my sig? It is not showing up on my computer for some reason.
Old 03-19-2004, 02:35 PM
WXboy's Avatar
WXboy
WXboy is offline
I can't see your sig. Admin. probably took it out along with all the other stuff. There are more rules around here than a daycare.
Anyway... I would agree that the D-max is the quietest out there. But between the Dodge and Ford, I think the Cummins is a little quieter. Our 6.0L PSD at work still rattles quite a bit. Who buys diesels for quietness anyway? Diesels are made to produce massive torque...and that energy releases more noise. It's natural.
Old 03-19-2004, 02:40 PM
MJD's Avatar
MJD
MJD is offline
Thats kind of funny. All that I had in my sig was "1993 F-150 4X4." It shows up under "edit profile."
Old 03-19-2004, 03:29 PM
FERacing66's Avatar
FERacing66
FERacing66 is offline
frankly mjd, we dont care about your signature=)
Old 03-19-2004, 04:08 PM
Ford15926's Avatar
Ford15926
Ford15926 is offline
between the dodge and the ford i think that the ford is supposed to be quieter beacuse of the type of injection.
ford uses indirect and dodge use direct. The direct is supposed to be louder, but have slightly more hp. The ford it just the oppisite. Less noise less hp.
Old 03-19-2004, 04:36 PM
The Kidd F-250's Avatar
The Kidd F-250
The Kidd F-250 is offline
The dmax is the quietest and the cummins and psd are around the same noise level but dont judge on buying a truck with its noise level. Thats no reason to buy a truck becuase its quiet.
Old 03-19-2004, 04:45 PM
crazycanuck
I have decided on either the Ford or Dodge, and it is a toss up between the two. I thought the noise factor may help make my decision.
Old 03-19-2004, 10:36 PM
sinister73's Avatar
sinister73
sinister73 is offline
The 04.5 Cummins, makes the same sound it always did, but now insted of being a loud grumble it's a very low, almost muffled grumble. The PSD is much quieter too, but still has that characteristic PSD cackle to it, which is a little louder than the Cummins from what I've heard.
I know I've lost it btw, now I'm talking of grumbling, cackling motors...lol. I agree - noise level should be only a small part in your decision either way - if at all. Do some research on both - infact do LOTS of research - choose well, it's your money.
Old 03-19-2004, 11:18 PM
theshyguy's Avatar
theshyguy
theshyguy is offline
Drive them and see whatt he noise level is inside, if you can tell the difference. Because that is where you will be when you hear the engine. I dont think there is much difference in any of them. But soime of the PSD have the pilot injection deactivated. Between all of the diesels, I'd rather have the 7.3. I love the sound it makes.
Old 03-20-2004, 01:04 AM
Frost13's Avatar
Frost13
Frost13 is offline
A sound test was done in this forum not too long ago between the 6.0 PSD, the DJunk, and the Cummins. I believe it was done in 4 locations: inside cab at idle, inside cab at 70 mph, grill at idle, and 40 yards away at idle ( these locations are not exact ). The 6.0 PSD was the quietest in all the tests. But I would rather have the louder 7.3 PSD or the pre-'03 Cummins in a Ford. (I want for me and other people to be able to hear the engine. )
Old 03-20-2004, 02:00 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
And more cry-babies. See the announcements section.
Old 03-24-2004, 12:49 AM
FordLariat's Avatar
FordLariat
FordLariat is offline
Unless you're a political assasin and you shoot from the truck!
In all seriousness, just test drive them both and see which one you like better. That's all that matters in the end, anyway, get the one that you like better, it's your money, and if you like the truck that you didn't buy better, you'll be kicking yourself for a long time.
Old 03-24-2004, 01:43 AM
johnsdiesel's Avatar
johnsdiesel
johnsdiesel is offline
The PSD is the loudest at idle, but it is actually quieter than the Duramax at highway speeds. The new Cummins is pretty quiet. I rode with someone who owns one of the new Cummins recently and was amazed at the difference. Main noise in the cab was the turbo whine. All three are fairly quiet so I can't imagine that noise will be an issue at all. Drive each one and pick the one you like best.
Quick Reply: Diesel noise Ford vs. Dodge
