Missing under load
Missing under load
Hello everyone. I'm new to FTE and I think this is one of the most helpful sites I've ever been to.
I have a problem that is driving me cazy. My 88 F150 5.0 5spd 4X2 has started missing under a load. The truck is basicly stock with a 92 Mustang 5.0 roller cam, Mac equal length shortie headers, rear converter removed and dual exhaust with no mufflers. The missing started out just once in a while but it has become all the time. I've used the search funtion and read everything posted about this and tried everthing that sounded like it would cure it.
1. Tune up- plugs, cap, rotor, wires, fuel filter, air and crankcase filters, cleaned IAC and EGR vavles.
2. Checked for any codes. Code 31, replaced EGR posision sensor. This fixed the problem until the next day and it was back. Code 31 set again. Found and repaired coroded ground for ECM at neg. battery cable, no change. Disconected vacume hose on EGR valve, no change. Replaced EGR valve, still no change.
3.Checked fuel pressure. KOEO 38PSI, KOER 32PSI. Filter in tank switching module has been removed.
This is becomming a bit expensive. Does anyone see something I'm over looking?
Thanks James White
Thanks James White
My pickup has a barely noticable miss when under load. It is not really a rhythm and it feels much like I am hitting a small bump in the road. I would like to know what it is, but since it is no big problem, I am not too worried. My friend thought that it might be the torque converter when he rode in my pickup, but since yours is a stick, that couldn't be the problem. I am going to check the timing on my pickup when I get the chance.
Did you test the EGR vacuum regulator (EVP or DPFE)? If it is not functioning properly, it will affect the EGR valve and position sensor. Check out Fordfuelinjection.com for testing procedures. I think this is the problem with my truck. Their wasn't a local dealer who had the part, so I am still waiting for it to be delivered.
Also, if the O2 sensor has more than 30k miles, you may want to consider changing it. Maybe try a good fuel injector cleaner, that's at least an inexpensive try at the problem.
Thomas Boersma
03-24-2023 07:46 PM
Thomas Boersma
03-06-2016 10:11 PM
