factory trailer light connector
Old Mar 16, 2004 | 10:48 PM
brown 4x4's Avatar
brown 4x4
Question factory trailer light connector
I borrowed a trailer from a friend which has the 6 pin round connector. I have the trailer tow package with the factory connector. No problem though, I had an adapter to plug into my factory 7 pin connector. Checked the lights on the trailer and they were all dim, turn signals were messed up, and the brakes were locked (I don't have a brake controller). We verified it wasn't a ground problem, and the day before I had checked my factory connector with a test light. I'm almost positive the adapter connects the pins to the standard positions. All fuses and relays are good and in place also. We never did figure it out, and ended up using his "tee" connector for the taillight connector from his '93. That worked fine. Any ideas on what happened? It's really got me puzzled.
Old Mar 17, 2004 | 04:10 PM
Lou Braun's Avatar
Lou Braun
I had the same problem. Some 7 pin to 6 pin adapter are not correctly wired for older series connectors.
Solution. Make your own adapter.
Lou Braun
pzp107
All Things Towing
May 17, 2013 08:12 PM
mitsudave
1997 - 2003 F150
13
Oct 24, 2012 06:27 PM
dlturner00
Aug 21, 2009 07:23 AM
hucka1a
18
Apr 7, 2009 10:56 PM
sherpa
All Things Towing
Jan 6, 2006 02:00 PM
