351w
Old 03-16-2004, 03:52 PM
RbsFord's Avatar
RbsFord
RbsFord is offline
351w
i have a 1990 f150 4x4 w/ a efi 302. i bought the truck w/ 143k
mile on it. i noticed the other night why fixing another problem that the valve train and bootom end is starting to rattle and so on. i been reading here today that a 351w will pretty much bolt right in except for some small changes. i am wanting the replacement motor to not have to rely on any computer or such if possible. what year and make of ford's came with the 351w in them so when i call a junk yard i can ask directed questions? any help will be helpfull thanks.
Old 03-16-2004, 09:48 PM
RLKBOB's Avatar
RLKBOB
RLKBOB is offline
If you plan on keeping your EFI you need the computer, just get the computer out of the 351 donor vehicle it'll plug in to your current harness.
Old 03-17-2004, 07:49 AM
RbsFord's Avatar
RbsFord
RbsFord is offline
thanks for the info, but i don't want the efi. i am hoping for a set up like my 76 f250 w/ a 360.
Old 03-18-2004, 02:04 PM
Mike G's Avatar
Mike G
Mike G is offline
You will probably have to go older, I'm not sure if the 351w came in the trucks (some will correct me if necessary). You will also need a trans as your curent unit is probably controlled by the computer also. Then there is the issue of emission testing your truck, if that is necessary in your state.
--Mike
Old 03-18-2004, 03:30 PM
RbsFord's Avatar
RbsFord
RbsFord is offline
emission's not an issue in SC (yet). the tranny is a manual w/od the computer does'nt effect the manual does it?
Old 03-21-2004, 04:18 PM
91f250460's Avatar
91f250460
91f250460 is offline
1986 or older to get a non-computer, carbed 351w.
Old 03-21-2004, 04:41 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
83-87(went EFI mid year) F-Series will get you a carbed 351W, 84 had 4bbl's optional, 85-87, were 4bbl only.
Old 03-22-2004, 08:00 AM
RbsFord's Avatar
RbsFord
RbsFord is offline
thanks for the info. this will help a lot.
SgtEnnen
32
08-28-2013 01:32 AM
v10squirrel
07-10-2007 08:54 PM
rsalter66
05-29-2007 11:57 PM
rsalter66
20
05-29-2007 09:42 PM
Quick Reply: 351w
