Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-15-2004, 08:52 PM
neer150 neer150 is offline
Garage is empty, add now
neer150 is starting off with a positive reputation.
when and what
when where the engines produced and what where they related too.
  #2 (permalink)
Old 03-15-2004, 10:32 PM
Ds7776 Ds7776 is offline
Ds7776 is starting off with a positive reputation.
from what ive read they were made in th60s and ive only seen one 534 in a 74 F750 i think it was a 750 anyway. I asked about them a while ago from what i understood they were a LARGE FE if im wrong please tell me i had the chance to buy a 477 but ran short of money, I stilll really want one.
__________________
1966 F100 longbed 352 4speed, 1969 F100 Ranger 360 auto, 1970 F100 Sport Custom 390 auto, 1973 F250 2wd 360 auto, 2 1976 F250 auto 2wd 390 Custom & 460 Ranger XLT, 1977 F150 custom 4x4 460, 1979 F150 custom 4x4 400 on 39", 2005 F150 STX supercab 4x4.
  #3 (permalink)
Old 03-16-2004, 05:49 PM
Kenny's Avatar
Kenny Kenny is offline
Kenny is gaining momentum as a positive member of FTE.
These engines were used in the late 1950's large trucks.
The 401 came with the F-850, F-950.
The 477 came with the F-1000 (standard), F-1100 (as an option)
The 534 came with the F-1100
Same for C-series (tilt cab), and T-series (tandem)
Not positive on this one, but I think they may even preceed 1957.
The Super Duty engines were kind of in a "family" of there own.
__________________
Kenny
  #4 (permalink)
Old 03-17-2004, 05:48 PM
Thomsen Thomsen is offline
Thomsen is starting off with a positive reputation.
HOLY COW! those are some big cube motors...does anybody know the hp and tq specs on these monsters?
__________________
1978 F-150 swb 4X4: 400, NP-435, 205, 38.5 Boggers
1979 F-150 4X4: 466, C6, 203, D60/Sterling 42'' Iroks
1986 F-350 CC 4X4: 6.9 IDI, T-19, D60/Sterling
1989 F-350 4X4: 7.3 IDI, ZF-5spd, D60/Sterling, Banks
1994 F-150 4X4: DD, 5.0, AOD
2000 F-250 4X4: Supercab, Powerstroke, 6-speed
  #5 (permalink)
Old 03-17-2004, 07:49 PM
Kenny's Avatar
From my '59 Ford Truck shop manual......
401 SD V-8
Horsepower..................226 HP @ 3800 RPM
Taxable Horsepower.....54.00
Torque..........................350 foot lbs. @1800-2300 RPM
477 SD V-8
Horsepower..................260 HP @ 3600 RPM
Taxable Horsepower.....65.00
Torque..........................430 foot lbs. @1800-2300 RPM
534 SD V-8
Horsepower..................277 HP @ 3400 RPM
Torque..........................490 foot lbs. @1800-2300 RPM
__________________
Kenny
  #6 (permalink)
Old 03-18-2004, 02:42 AM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a good reputation on FTE.82F100SWB has a good reputation on FTE.
I'll have to dig out my 81 heavy truck shop manual... I know the 477 and 534 are in there, but, I forget if the power ratings are too...
__________________
96 F350 Crew Psd/5 speed,/4x4... $600 special
96 F250 XLT PSD/5 speed/4x4... Freebie!
92 W250 LE, 4x4/CTD/G360/D60/D70U
86 F250 HD 4x4, 6.9/T19/broken D44 TTB junk/10.25.
8? F100 4x4 Mild 460/T19 D60/welded 10.25/44 Boggers,
It's not what you BUY, It's what you BUILD
  #7 (permalink)
Old 03-18-2004, 05:26 PM
FERacing66 FERacing66 is offline
FERacing66 is starting off with a positive reputation.
well the torques prettey good on the 534 but is there any high peformance products you coud get for it.
__________________
1966 F100
Twin I Beam
4spd
Custom Built by FERacing66
352FE V8
Holley PowerShot Air Cleaner
Holley 600 4brl Carb
Ford 4brl Intake
Crane PowerMAX Cam (901)
Headers
  #8 (permalink)
Old 03-18-2004, 07:46 PM
82F100SWB's Avatar
Nope, these are strictly industrial engines, low compression, low revving high torque...
They are positively HUGE also...
Click the image to open in full size.
That one is missing the oil pan, that's a Holley double pumper on there, and those are 8x8's(IIRC, might be 12x12's) it's sitting on...
Have fun fitting it any automotive application.
__________________
  #9 (permalink)
Old 03-20-2004, 06:19 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
That ain't no double pumper on there, that's a single line Holley, probably around 600cfm.
They do favor the FE design though. Especially the heads. Where does the distributor go? behind the turbo charger looking waterpump?
I've never seen any of these dinosours before. It looks really heavy!!!
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
  #10 (permalink)
Old 03-20-2004, 06:44 PM
82F100SWB's Avatar
IIRC, double pumper means it has an accelerator pump on each bowl... Which that unit does, it's just an oddball industrial application carb.
I forget if the distributor is at the front, or goes on top of the governor at the rear... been a while since I had the tarp off of that thing.
__________________
  #11 (permalink)
Old 03-20-2004, 08:53 PM
Kenny's Avatar
The distributor is up front, behind the water pump.
__________________
Kenny
  #12 (permalink)
Old 03-21-2004, 11:18 PM
LxMan1's Avatar
I see, It didn't look like it had a rear pump, but it is hard to tell by the angle of the picture. I stand corrected.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #13 (permalink)
Old 03-23-2004, 09:53 PM
mikebon08 mikebon08 is offline
mikebon08 is starting off with a positive reputation.
I've seen 534s as late as '82, a lot of small-town fire trucks using Ford cabovers have 534s. Bunch of them still around too.
  #14 (permalink)
Old 04-05-2004, 08:28 PM
534Seamaster 534Seamaster is offline
534Seamaster is starting off with a positive reputation.
There are two 534's for sale on EBAy right now.One for $500 running. 534's came with a Holley that was a governed unit with a second set of throttle plates connected to the governor. The Holley was rated at something like 375CFM. I have a Ford 534 Seamaster Marine engine running in a boat. Smooth & dependable but not very exciting, except to know it will still be running for a long, long time.
  #15 (permalink)
Old 04-17-2004, 10:47 PM
alvaze alvaze is offline
alvaze is starting off with a positive reputation.
HI,i have a truck with 534engine, its very strong, but, i need convert to gas my truck,
the problem is with power, because its reduce,
where find information about 534 specifications i need links
Tags
361xd, 401, 477, 477534, 534, boring, ci, engine, engines, exhaust, ford, manifolds, superduty, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
