97 f150 cam sensor shaft bent
Re: 97 f150 cam sensor shaft bent
Originally posted by mark k t
cam position sensor bad took it off an found the arm was bent down by the broken sensor is it replaceable an how
Hey, That happend to me also. I have a 97 4.2 . Canshaft Position Sensor went up - the little magnet was missing, and you could put your finger right through the hole where the magnet was suppose to be.
I seen the syncronizer shaft and the metal tabs were bent also like you describe. The mechanic told me that the shaft could also starve your engine from getting *oil. Im not sure if that's true though. He told me briefly that this is some how connected to the oil pump? It costed about 300 to get it all done.
Earl
Earl
