Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-10-2004, 10:10 PM
KeelarPluto KeelarPluto is offline
Garage is empty, add now
KeelarPluto is starting off with a positive reputation.
CrankCase Air Filter Location??
I went to the local parts store and looked up all the filters for my motor and bought a few of them, I bought the Air Filter and CrankCase Air Filter which I cannot seem to find on my motor. They had another filter listed for something else, but I didn't bother getting that one, this time around...I have a 302 5.0L...How can I find the Filter for the CrankCase?
__________________
-Mike
1990 F150 302 SuperCab 2WD
2002 Mazda Protege 2.0
  #2 (permalink)
Old 03-10-2004, 10:13 PM
ocb ocb is offline
ocb is starting off with a positive reputation.
ithink its in u,r air cleaner
  #3 (permalink)
Old 03-10-2004, 11:32 PM
Ford_Man_302's Avatar
Ford_Man_302 Ford_Man_302 is offline
Ford_Man_302 is starting off with a positive reputation.
ya its the little filter that is at the bottom of your air box
  #4 (permalink)
Old 03-10-2004, 11:49 PM
Leo_T Leo_T is offline
Leo_T is starting off with a positive reputation.
I was down to the Zone a few weeks ago, and tried to get one for my 96 5.8.
He said that it wasn't listed. Figured I change it out while I was doing the air filter. No such luck! Is that a dealer item? I looked when I changed the air filter, but I didn't see one at the air box. Now what?
__________________
96 E-150 351 E4OD
OBD II
  #5 (permalink)
Old 03-11-2004, 07:02 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
There's not a crank case filter on a '96. It pulls air from the filtered air stream aft of the mass air meter. There's a hose coming from the back of the 'y' going to the drivers side valve cover.
__________________
Eric
'87 F150 302 ZF 5 speed 4x2
  #6 (permalink)
Old 03-11-2004, 07:45 PM
Thanks EPNCSU,
Nice to hear from someone who knows.
__________________
96 E-150 351 E4OD
OBD II
  #7 (permalink)
Old 03-11-2004, 08:32 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Quote:
Follow the 1" sized tube that follows the air intake tubes. It goes to the box, the little filter on the end of that small tube, inside the air box, is what you want to change.
__________________
Justin
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
  #8 (permalink)
Old 03-12-2004, 05:58 AM
Thanks guys, Found and Replaced...It seems that over the years from the previous owner the C.C. Filter acquired some oil...Would this constitute blowby? It was whiteish and foamy, sort of what water in oil looks like after going river running with a motor, anyways what can I do and what do I look for over time in this new filter to see what my motor is actually doing? Thanks again for the help...
__________________
-Mike
Tags
1990, 2002, 302, 50, air, case, crank, crankcase, f150, filter, ford, location, mazda, protege, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
