clunking/popping noise from front axle?
I have a problem with something clunking in the front end of my truck, it almost sounds more like a popping noise. Could this be something ready to break in my axle? Possible U joint? Shocks? It has been happening for about a week so i cant be sure when it happens but i think it happens when i make a fairly sharp turn at slow speeds.
Thanks
Thanks
Check the rivets holding the front crossmember to the frame, I would bet they are loose. It is a fairly common problem that will cause the popping during low speed turns just like you describe. Get under the truck and have somebody you trust turn the steering wheel back and forth. Watch very carefully where the crossmember meets the frame. Mine moved around 1/8" to 1/4". While you are under there, check the crossmember itself VERY carefully for cracks around and above the axle drop brackets. You didn't say what brand of lift you have, but the Tuff Country lift that was on my truck when I bought it caused some major cracks. Cost me some serious $$$ to get everything welded up.
I had two 93 F-150's that made the same sounds. Popped when turning and when going into driveways. It was the rivets holding the crossmember just behind the motor. Start your motor but leave it in park then turn your steering wheel all the way in one direction then all the way back the other. If you hear the poping then have someone turn the steering wheel again while you look under the truck at the cross member between the door and the motor and you will see it move ever so slightly. If you can't see it then you can feel it move. If it doesn't pop just by turning the steering wheel while sitting still, in park it will when the rivet wares somemore. The solution is to have it reriveted or welded. I was told that the weld would brake after sometime so I had mine reriveted at a bodyshop, Stop the noise immediately.
both my Bronco and my F-150 popped as described and they were both due to a bad radius arm bushing. The bushing is split into 2 parts, the forward and aft part. In both cases, the forward part had disentigrated, but still looked fine when I crawled under the truck. I only found the problem when I installed the lift kits and was replacing the bushings. They retail for about $10.00 in town and even if they don't need replacement, the aftermarket ones are a ton better than the stockers.
