Fuel inertia cut off switch, 89 F250
09-03-2001, 08:15 PM
on
Could someone Please tell me where this switch is? I've looked all over under the dash. Even pulled the glove box out. Where is that sucker?
09-03-2001, 10:02 PM
on
Should be in the kick panel on the passenger side. (farthest plastic panel on the right in front of the door.)
09-04-2001, 03:49 AM
on
I've been in there and only found the emergency flasher element and some wires and plugs. I must be blind. I'll look again. Thanks.
Steamer.
09-04-2001, 02:14 PM
on
Check your owners manual, it should tell you. Also on the new SD's there is a hole in the kick panel to stick your finger in to reset it, you might look for that. On my 90 150 it was on the firewall just behind the brake pedal. Either way it should be easy to access. Generally they design the system that way.
Good Luck,
Rob
09-04-2001, 08:30 PM
on
My 89 f150,s is by the brake peddle inside the cab.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
09-06-2001, 12:07 PM
on
09-07-2001, 04:08 PM
on
I found it. Same place as Nitro's 150. Good thing it wasn't a snake. Thanks guys. Nice site ya have here.
Steamer, first timer.
ligito
1999 to 2016 Super Duty
09-20-2016 06:56 PM
gman97005
12-12-2014 06:32 AM
aintskeered
02-03-2012 09:59 AM
mlbmd
18
04-02-2009 09:55 PM
FordTruckGuySTX
05-02-2006 06:33 PM
89 ,
cut ,
cutoff ,
duty ,
emergency ,
f150 ,
f250 ,
ford ,
fuel ,
inertia ,
location ,
shut ,
super ,
switch ,
truck
