Will seats from a 97 f-150 fit into a 96 f-150? What years will interchange? I have a bench seat and I want to put bucket seats in. Anyone want to trade, I have a 96 f-150 with a gray bench seat, pretty good condition.
i think they will interchange. i have a 96 bench seat in my 89 bronco. the bolt holer are already drilled under the carpet and there are buts welded to teh body already. just find some seats and bolt them in
FWIW, I could use the bench-seat from your '96 in my '97, if it's gray cloth in decent shape and it folds forward ('97 F-250HD used the same body as the earlier ones, so that one WOULD interchange). Where in NY are you? I'll be passing through next Monday to pick up an engine from NJ.
Sorry but its gray vinyl, plus since i drive the truck to work everyday I can't get rid of my seat til I get a new one. Thanks for that info about the f-250, I forgot about that. By the way, I live in long island. It's really amazing the money they want for good seats and how hard it is to find used ones for my 96. I'm in the military, Coast Guard, and can only afford so much so I'm limited to finding something used for the most part. I've got one more question, will newer explorer seats fit into a 96 f-150 and will any other ford seats fit into my truck?(bronco, explorer, excursion, escape, etc)
hell anything will fit with a little ingenuity....i've seen seats from a dodge in a ford and vice versa....if you can redo the brackets then you can make any seat work for ya. it all depends on what your capable of and how much work you wanna do. goodluck
I would look into swapping the seat tracks. I installed some 80 something GT seats in my 78 bronco and the seat tracks swapped from one to the other. There was one whole for the seat track on the GT seats that was not tapped so I tapped it and I had all 4 bolts holding the 78 seat ttracks on 80 something GT seats.
