wiper control. will not shut off
My wipers will not shut off (intermittent lowest speed)
I replaced motor, wiper control module (WCM) and replaced the multi function switch a couple years ago so I don't think any of them are failing (although the switch is after market)
I downloaded a PDF technical bulletin from one of our members describing what to do to troubleshoot the problem. I have done everything according to instructions.
I am at a loss. The only thing left that I would like to check is Ground "F" which according to the wiring diagram is located behind bottom of left cowl panel.
I don't know where they mean.
Is there any technical members willing to add their expertise to this?
I have already replaced the wiper motor but will check the park circuit on the new one. I can't tell exactly where you have the jumper on the diagram.
I checked continuity on both black wires on wiper control module to battery ground. I have continuity
The tech sheet told me to check continuity between 28/56 and also 61 and chassis ground. Both are good
to do the Park Test the wipers must be OFF the park position.... this is why you disconnect the battery while the wipers are off park like in the middle of a stroke... when you do the test the motor should make 1 cycle then Park.
1. Connect a jumper lead from the low speed terminal of the wiper motor connector to park return terminal of park switch connector.
2. Jumper both windshield wiper motor and park ground switch terminals to battery ground cable.
3. Connect a jumper lead from the battery positive terminal to park feed terminal. Wiper motor should cycle once, then stop in park position.
EDIT: as far as that goes you can Meter across the park switch Terminals and just check if the switch is actually "Toggling"
The control Module or Governor is not too complicated 3 transistors a relay and few diodes and couple resistors, I probably have the schematic for it stashed away some place too.
Maybe you still have your old motor, you could plug it in without installing it and use it as a Test subject.
EDIT the Plug on the bottom is for the motor itself the upper Black Plug is for the park switch
In figure 1 that I posted the motor is upside down in relationship of how you see the connectors when mounted in your truck, I also own a 93 F250
one thing I can say is IF the park test Passes then I would Look at Connector C202 (Big One under Brake Booster on Firewall)
the park switch signal goes thru it to the Governor and in the Governor(Module) it only goes thru a Normally Closed Relay Contact then back thru C202 to the Low speed terminal on the Motor........ High Resistance in that Line can cause Park skips or Delayed Park
Good Morning. Just a few questions before I go out to try test. Your motor showing the jumpers appears to be totally disconnected from the system. I will get motor in "off park position" before disconnecting both plugs.
It appears Dk Blu/org is the low speed term. The park return appears to be the blk/pnk term. The wiper motor & park grnd switch term appears to be the yellow/red and the black which I will jump to battery ground. The park feed term appears to be the same as the park return term?? which would go to battery pos? I think I have some of the connections incorrect. Sorry, the terminology on the blueprint doesn't really tell you what they are called.
