stall speed
Like texan said the cam shaft is a big factor in selecting a stall. If you have a cam that has a power band from 3,000 to 7,000 then you would need a stall converter around the 3K range because that's where you power band starts. if you have a can that runs well from 1500 to 5500 then a stock converter will be fine but it would perform a little better with a little more stall than stock.
You do not install a stall converter to improve performance of a car or truck. That is not what they are design to do. A stock motor has a slight stall in the converter and a race motor will have a stall converer to fit its power band.
If you install a 2,800 stall in a stock motor you would have nothing for power because you are half way through your power band before you ever get moving.
The best thing to do if looking at or for a stall converter is to call the cam manufacture and see what they recommend. For the most part it may be listed already in the description of the cam.
zmcarideo
35
03-29-2015 06:56 PM
Brettboat
05-11-2014 10:10 AM
Fordenthusiasts
13
10-10-2007 08:11 PM
