Tire size chart?
Old 08-16-2004, 02:36 PM
firemed's Avatar
firemed
firemed is offline
Hi all,if you do the 1 inch leveling kit can you run say a 265/70/17 or 285/70/17
  #62
Old 08-16-2004, 05:25 PM
superrangerman2002's Avatar
superrangerman2002
superrangerman2002 is offline
Welcome to FTE!
If you have 265/70r17's as your stock size, you can run the 285/70r17's with out the leveling kit, but the leveling kit would make it look real nice.
  #63
Old 08-17-2004, 04:52 PM
superrangerman2002
hmm, never heard of a 265/60/r17 being a stock oem size, but you will still be able to go with the 285/70r17s.
  #64
Old 09-02-2004, 09:04 PM
bubahyde's Avatar
bubahyde
bubahyde is offline
Smile
I am also running 315/70R17 on my Expedition (stock)(w/weld wheels)
I have NO VIBRATIONS
I didn't want to cut the black plastic so I spaced the front bumper out 3/4"
I ,as others have stated get a little rub on the frame at full lock
(NO BIG DEAL)
Picks are in the gallery
  #65
Old 10-12-2004, 11:43 AM
superrangerman2002
There won't be a big problem with going with the "P" rated tires as that's what 99% of F-150s come with stock anymore.
An 8 ply tire is kinda overkill for a F-150, 6 is best, and 4 will do the job.
  #66
Old 10-28-2004, 06:53 PM
superrangerman2002
Originally Posted by RustyWallace
i need help
im thinkin of 275/7016
my stock are 255/75/16
whats the differnece between 70 and 75?
First set of numbers is the section width in mm.
Second set is called the "aspect ratio", it is a ratio of height vs section width...the closer too 100, the taller and narrower the tire, and the closer to 0, the wider and shorter the tire.
Are you sure that the stock size is 255/75r16 instead of 255/70R16?
It's been a while since I've seen a 255/"75"R16. I'm not real sure if you can get the size you are looking for in a truck tire...but I may be wrong.
http://www.bfgoodrichtires.com/asset...g_trail_ta.pdf
You can use the following chart to get an idea of how width and height chance with different sizes, compared to your oem size. Or you can google "tire calculator" to find differences in tires as well.
  #67
Old 11-01-2004, 09:03 PM
broncbuilder's Avatar
broncbuilder
broncbuilder is offline
I had 35x12.50-16 Thornbirds on 16X8 wheels with 3 1/2" backspacing with a 2" body lift. All I did was trim the air dam a little and remove the mud flaps. I have not touched the torsion bars. All i had was a little rub on the frame but that was from the sidelugs. Tires actually measured 14.50 from sidelug to sidelug.
  #68
Old 11-03-2004, 11:24 PM
AzBlueWolf's Avatar
AzBlueWolf
AzBlueWolf is offline
Talking
I have a 3.5' fabtech performance lift for 4x2's
LT285/75/R16 Dominator Sport A/T's
minor rubbing on sharp turns
(note) don't make sharp turns
Mark
01 F150 supercab Flareside 5.4 auto
  #69
Old 11-04-2004, 10:12 AM
renrutkcir's Avatar
renrutkcir
renrutkcir is offline
Just to let you know, the Duelers had a 30 day test ride on them. Took back the
P265's, got the LT265 (50,000 mile like most of them)...big difference in the braking and handling - got rid of the understeer and slower braking of the P rated tire.
Dont settle for less than the rating on the door jamb.. ( paid about 110 each on sale)
Later, off to the Vermont woods in a couple of days.
  #70
Old 11-19-2004, 01:09 PM
lariatrider's Avatar
lariatrider
lariatrider is offline
255/70/16 is 30.1 inches tall 265/75/16 is 31.6 inches tall. This translates into 3.2MPH difference. Speedo reads 60 you are actually going 63.2MPH! You will lose a small amount of low end torque, you will notice this when taking off from a stop. The loss probably will not be that great and you may hardly notice it at all. The 265's will be wider by approx 1/2 inch or so, handling will inprove as well as cornering. Hope this helps!
lariatrider rides on.....
  #71
Old 11-19-2004, 02:01 PM
bubahyde's Avatar
bubahyde
bubahyde is offline
I know if you work from the numbers that is works out that a 265/75R16 is about 1'' bigger, but please keep in mind every tire manufacture makes there measuements at a different spot. In my past life I worked with and engineering group at Ford. There was a large push to put a 215/50R16 on the SVT contour that came with 205/55/R16 Goodyears. Ford switched to the BFG G force 215/50R16. They got there larger number on the sidewall but the 205 goodyear was accually a wider tire. Goodyear measures the contact patch, BFG measures sidewall to sidewall.
My feelings are this, 255/70R16 is your factory size. They offer a 265/70R17 as an option (4x4 lariat or fx4) The 265/75R16 is very close to the 265/70R17.
You will notice nothing in switching to the 265/75R16. That is a very minor size change. If it was me I would be going to the 285/75R16.
That seems to be a easy, no issue, up size to switch to.
  #72
Old 11-19-2004, 02:17 PM
lariatrider
Using the goodyear rt/s as the guide for my measurments, as they are typically the stock tire that comes on them, the measurment are 1 1/2 inches taller. This WILL make a difference!! Using a revolution formula for the diameter of the tires your speedo WILL be off 3.2 MPH. This is a fact, check it, recheck it, and check it again, but, it is what it is. As far as performance you may not notice the low end power loss, if a driver doesn't pay attention they will never notice it. As for the 265/70/17 they are the same height but they are wider. If you want cornering get stiffer sidewalls ie:low profile tires and larger rims. the larger rim and less sidewall they rougher the ride but better handling. The smaller the rim and the larger the sidewall the smoother the ride but less ability to handle cornering at higher speeds. This is all due to the give of the sidewall of the tire. Yes bubahyde very good point about comparing tires of the same brand or taking actual measurments, make sure the rim mounting width is the same also.
  #73
Old 11-25-2004, 02:00 PM
waynetruitt's Avatar
waynetruitt
waynetruitt is offline
Is this from experience, or from research.. I too have a '00 F150 4x2 with p235/70/R16's on stock rims.. i was thinking of going a little larger, but don't want to affect performance..
Wayne
  #74
Old 11-25-2004, 02:03 PM
waynetruitt
Originally Posted by '00 F-150
I know with my truck '00 F-150 4x2 if I try to put bigger tires on, my tow capacity goes way down and I lose lots of power not to speak of the wheel travel that is lost due to the larger tire.
  #75
Old 11-25-2004, 02:08 PM
waynetruitt
Originally Posted by Shazaam
Ok I have read all the stuff in this trend and I am still not really sure what I can do with my truck to add some height. I want to add some new tires and a lift but is this going to mess with my factory warranty?
If I don't lift my truck the biggest tires I can go with are 29in tall 265/65/16 is that correct? And if I add about a 3.5" lift I can add 33in tall 285/75/16? What are the 2.5" blocks for? Also the price that was listed on here by someone said this was close $600.00 - $1,500.00 I assume this doesn't include tires correct?
By the way anyone in San Diego, Ca. Know of a good place to go to get this done beside PG I hear they are really pricey. What I would like to do first is put larger tires on my truck without having to change out the stock rims or lift it. So I guess I can only go with the 29in tall 265/65/16's does anyone make good meaty looking tires for this size.
I have the same question that you do for a '00 F150 4x2 Supercrew..
Interested in what you find.. of course.. i'm just to your post now, so may be answered later on in this list of posts
Wayne
Quick Reply: Tire size chart?
