standard 2 speed transmission?
Had a '68 Chebbie Impala 307 4 door POWER-GLIDE as my first car.... grandma n grandpa's hand me down car. I don't know what rear end was in it, but when I wanted to pass doing 50mph.. step on the gas and it would scream up to 60 or so then kick back over into high gear. I don't know how many years they made it, but when I junked the car, both the 307 and the power glide were sold within a week. Ahhh the memories. What a great little league hauler before the mini-vans.
Tony
Tony
The ford o matic is not very good. Its cast iron, and doesn't take a lot of abuse. Remember that it was built/designed during the 50s.
If you want a true racing two speed manual or automatic, its gonna be custom.
one of the strongest manuals available, and relatively light is the Ford toploader, its a 3 speed, but with the many close ratio gearing options, its perfect. Its got a removeable bellhousing, so you can switch it to anyhting you like. Just about any good tranny guy can build one of these, for about $350.
If you are dragging, you are gonna want an automatic, and thats where the C4 comes in. You can cheaply ($125) build it to take the abuse of a strong 460.
You might wanna head over to http://www.fordmuscle.com and check out the tranny buildups those guys have. They have a lot fo knowledge.
The weight of the powerglide was a plus but it also has less parasitic power loss than most others. The c/4 is the closest thing Ford has and can be built to take a serious small block. From what I have read you would still want to use a C/6 for a snorty big block. The C/6 is bullitproof but saps off a good bit of power to turn the pumps and all, same with a turbo 400. None of the Ford 2 speeds or cruise-o-matics should be consider for anything other than an original restoration, no performance potential at all. There was never a C/4 made to bolt to any big blocks but I am sure there must be adaptors out there. Also they are building the AOD to handle a decent small block for street applications. Most of them favor getting rid of the lockup due to its weaknesses.
