General Automotive Discussion
standard 2 speed transmission?
Old 02-15-2004, 12:43 PM
DragTruckin's Avatar
DragTruckin
DragTruckin is offline
hey i'm lookin for a standard 2 speed racing transmission for my truck. i know chevy makes one ..i think its called a powerglide? but i was wondering what ford has for drag racing transmissions.
Old 02-15-2004, 05:41 PM
User 050423's Avatar
User 050423
User 050423 is offline
I thought the powerglide was an auto?
No idea on the ford though...
Old 02-16-2004, 04:40 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
We always called those Cheby boxes SSB's
Old 02-16-2004, 09:04 AM
Andysutt's Avatar
Andysutt
Andysutt is offline
Ford made a transmission like the powerglide
The name escapes me but I think something simple
They are automatic transmissions, but you can shift them manually also.. as we have one in a drag car, but I prefer the C4 and the C6s
Old 02-16-2004, 09:36 AM
fordeverpower's Avatar
fordeverpower
fordeverpower is offline
yeah the 2 speeds are powerglides. i don't know that a person would want them in there vehicle.
Old 02-16-2004, 10:02 AM
Andysutt's Avatar
Andysutt
Andysutt is offline
in a drag vehicle they are pretty good...
atleast 1/2 of the ford guys I know that run a C4 only use 2nd and third, or first and second... so the powerglide works pretty well... you can get different ratios for them
Old 02-16-2004, 12:19 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
CowboyBilly9Mile is offline
Some people like powerglides (sometimes referred to as slipNslide) because they are very light.
Old 02-16-2004, 12:32 PM
Andysutt's Avatar
Andysutt
Andysutt is offline
If you want a actuall MANUAL 2 speed transmission, call up Linco
Im sure Doug Nash or others make them also
Old 02-16-2004, 06:14 PM
otto's Avatar
otto
otto is offline
I think the Ford~O~Matic was a 2 speed auto tranny, fords auto tranny I do believe, nobody uses the tranny for anything performance, not to mention fords ever changing bellhousing bolt patterns
Old 02-16-2004, 09:02 PM
Andysutt's Avatar
Andysutt
Andysutt is offline
Fordomatic that was it
Old 02-16-2004, 09:28 PM
DragTruckin
so is this fordomatic any good? strong? good for drag racing? can handle alot of hp?
Old 02-17-2004, 12:24 AM
Tony G's Avatar
Tony G
Tony G is offline
Had a '68 Chebbie Impala 307 4 door POWER-GLIDE as my first car.... grandma n grandpa's hand me down car. I don't know what rear end was in it, but when I wanted to pass doing 50mph.. step on the gas and it would scream up to 60 or so then kick back over into high gear. I don't know how many years they made it, but when I junked the car, both the 307 and the power glide were sold within a week. Ahhh the memories. What a great little league hauler before the mini-vans.
Tony
Old 02-17-2004, 12:39 AM
Andysutt's Avatar
Andysutt
Andysutt is offline
Yea the 307s are hard to find, and powerglides are getting that way
Old 02-17-2004, 02:35 AM
Matts72's Avatar
Matts72
Matts72 is offline
The ford o matic is not very good. Its cast iron, and doesn't take a lot of abuse. Remember that it was built/designed during the 50s.
If you want a true racing two speed manual or automatic, its gonna be custom.
one of the strongest manuals available, and relatively light is the Ford toploader, its a 3 speed, but with the many close ratio gearing options, its perfect. Its got a removeable bellhousing, so you can switch it to anyhting you like. Just about any good tranny guy can build one of these, for about $350.
If you are dragging, you are gonna want an automatic, and thats where the C4 comes in. You can cheaply ($125) build it to take the abuse of a strong 460.
You might wanna head over to http://www.fordmuscle.com and check out the tranny buildups those guys have. They have a lot fo knowledge.
Old 02-17-2004, 03:12 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
The weight of the powerglide was a plus but it also has less parasitic power loss than most others. The c/4 is the closest thing Ford has and can be built to take a serious small block. From what I have read you would still want to use a C/6 for a snorty big block. The C/6 is bullitproof but saps off a good bit of power to turn the pumps and all, same with a turbo 400. None of the Ford 2 speeds or cruise-o-matics should be consider for anything other than an original restoration, no performance potential at all. There was never a C/4 made to bolt to any big blocks but I am sure there must be adaptors out there. Also they are building the AOD to handle a decent small block for street applications. Most of them favor getting rid of the lockup due to its weaknesses.
Quick Reply: standard 2 speed transmission?
