78 E350 RV electric choke
I have a 78 E350 16ft RV with a 300Cid 6cyl and 1bbl carb. It had an electric choke and a heat tube that was not hooked up. I had hooked up the heat tube and it worked okay but the electric wire had no place to hook to.
Well the choke spring broke and I tried to put on a manual choke cable. It sucked. I have now got another electric choke and wish to hook it up. The parts guy said to hook up to a wire that comes on when the ignition is turned one.
I need piece of mind on this as my wife will be using this a lot by herself.
What wire is the best for this. Any help? THIA
Eric
Eric
'77 F100 Custom
12-06-2016 09:01 AM
dan240
12-31-2015 11:40 AM
Tkc432
06-27-2015 01:00 PM
