mpg? 4.30 vs 3.73 gears
At 70 MPH my 3:73 is running at 1900 RPM. Same day, I drove the 4:10 and at 70 MPH i was at 2200 RPM. There is a difference. Dad has the 4:10 and I get 11.5 when driving it mixed, I get 13.2 when driving mine mixed. I am not sure, but I think you can check the ratio in the door jam.
I have a buddy at the river who has the 6 speed w/4:10, and he gets 14.5 mixed driving. But he bought his in Nevada where you can get the 6 speed in an V10. I cant here, or I would have gotten the 4:10.
I'm not sure there's a big mileage difference between the 3.73s and the 4.30s - while the 4.30s definitely increase the RPMs, I don't think that they use much more fuel.
On my truck - 2004 4x4 crewcab auto w/4.30 gears - I've gotten an all-time best of 13.5mpg and an all-time worst of 9.9mpg, and overall I'm averaging about 11.5mpg. Since all 8,000 miles on my truck were put on in the last two months, those are winter mileage figures - so summer mileage figures would probably be a little better. Also, at least half of those miles are with the hubs locked, and probably 1,500 of those miles I had the truck in 4-hi - and even running 4-hi I've only ever had two tanks that dropped below 10mpg (both at 9.9). While I've towed with the truck a few times, it's usually for less than 50 miles - so I don't really have any separate towing mileage numbers.
This is a mixture of perhaps 75% highway driving (at 70-80mph) and about 25% city driving. At 80mph I'm turning about 2,700-2,800 rpm - and my tires are 235/85r16s, which are about 32" tall.
Anyway, as far as I can tell the 4.30 gears don't seem to hurt mileage very much.
LK
LK
circlev,
its all in how you drive it. i can grandpa mine around (3.73 auto) and get 11 or so in town and over 16 on the highway...
or i can drive like i normally do and get about 9 in town and 15 on the highway.....
if you have a super heavy foot, i wouldnt expevt to get over the single digits though.
my best is 17.5 my worst is 3 (the 3mpg was comming up a loooooong mountain hill, pulling about 12kat 45 -50 mph)
Similar to LK...
2001 Crew Cab 4x4, V-10 auto, limited slip 4.30 gears with 26575R16 tires.
City - 8-10 MPG
Highway - 12-14 MPG
Daily driver - 11.5 MPG
Towing 28' travel trailer - 7-10 MPG, depending on terrain & wind
The 4.30 gears reduce high speed mileage a little, but give you several advantages over the 3.73 gears:
- As you put bigger tires on your truck the ratio drops... Starting at the lower 4.30 may give you a high enough ratio to not require new gears.
- Higher tow rating... Click here and click on the "Towing Capacities" along the left side.
- Better acceleration from a stop.
Edmo
City - 8-10 MPG
Highway - 12-14 MPG
Edmo
The 235/85r16s are the stock all-terrain tires you can get with the FX4 package. I've thought about going with larger tires and a small lift (which is part of the reason I got the 4.30s), but for now I'm going to keep these tires until at least spring - they seem to do pretty good in the snow. At least, they're good on-road - there's too much snow to get off-road anymore, even if I did have the lift and larger tires.
Maybe one of those track setups would work...hmmm...
LK
LK
Re: mpg? 4.30 vs 3.73 gears
Originally posted by CircleV
I'm looking for a used F250, probably with a v10 and I wondered how milage compared. I will be putting on at least 285's and maybe even up to 315's if I can make them fit w/o too much lift.
Is there an easy way to check a used truck to determine what ratio it has?
For example:
F1 = 3.73
F2 = 4.10
F3 = 4.30
56panelford
64
02-11-2013 06:48 PM
thendrix
10-24-2007 06:56 AM
skeleton33
02-24-2005 06:29 PM
loudfords
11-22-2003 10:29 AM
hawkrod
08-18-2003 11:55 PM
