Will OEM roller lifters work in a 1970 302?
Does anyone know if I can take roller lifters out of a 5.0 HO and use them with the spider plate in a 1970 302 block, with little or no modifications to the block? Some one told me that the lifters will fit right in place but I am afraid that the rollers are larger than the factory Hydraulic lifters that came in the engine. any help I will be greatfull. Thanks
If you use the ford stock roller lifters you need a small base circle cam when using a non roller. You can not use the ford stock roller cam and roller lifters in a non roller block. The lifter bores are to short for that combo. I think some one makes a specail roller lifter for use with a stock ford roller cam in a non roller block.
1bad67sbf
04-21-2010 09:02 PM
Torque1st
22
10-24-2007 02:03 AM
Huntersbo
09-24-2005 07:28 PM
