1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Twin I-beam to strait axle swap.
Old 06-18-2002, 03:53 PM
knwrth2's Avatar
knwrth2
knwrth2 is offline
I have a 1997 F250 Heavy Duty 4x4. It has twin I-beam front suspension and I would like to swap it out for a Dana 60. Is a Ford dana 60 axle from a 78-85 truck similar to the Dana60 found in a 1997 F350 4x4? I am wondering because I have herd of people swaping the twin I-beam for a Dana 60 from the same year.
Thanks
Old 06-18-2002, 06:42 PM
nickdoni's Avatar
nickdoni
nickdoni is offline
I put a 97 dana 60 in my old 83 f350(truck came with heavyduty twin I that year )and it fit great.Call your local bone yard and ask some questions.They deal with this stuff all the time.Good luck!
Old 06-18-2002, 11:05 PM
redranger1's Avatar
redranger1
redranger1 is offline
the only dana 60 monobeam axle that will fit in yer truck exactly is out of an 80-97 1 ton ford. the pre 80 dana 60's have a more narrow spring pad pattern. the 99 and up is only about an inch wider so you can make that adjustment pretty easily up by the frame. the only prob with that is that the wheels on the front wont work on the back and visa versa. good luck with the swap.
-nathan
Old 06-19-2002, 06:39 AM
Lifter F250's Avatar
Lifter F250
Lifter F250 is offline
civicmindeddogooder
27
04-29-2021 07:40 AM
1972RubberDuck
16
11-12-2016 01:30 PM
Pete S
01-17-2016 01:23 AM
lakechicken
11-02-2014 08:41 PM
zrt600guy
05-11-2008 01:10 AM
Quick Reply: Twin I-beam to strait axle swap.
