Help! 1999 Explorer Problems
I bought my 1999 Explorer (v6, 4liter, xlt) back in April. I didn't have any problems with it until about two months ago when it started getting cold. It's started to idle very rough for the first few minutes until it warms up. From time to time I will have to start two or three times because it dies. Once it gets warmed up I have no problems out of it....
Just yesterday though (Jan. 22) my check engine light came on while I was on my way to work. Once I got to work I checked all my fluids, belts, and hoses and they all seem to be fine. The vehicle seems to be running with out problems, but the check engine light just stays on. Any clues to what the problem may be?
Thanks!
Thanks!
You need to get the vehicle scanned for codes in the computer.
Get us the code and we can help you !
Common problems are
Iac valve
02 sensors
lower intake gaskets
dpfe sensor
egr valve
maf sensor
throttle senser
What happens is you go through so many drive cycles before the pcm post a code to a problem
With the code s we can help you
autozone will scan for free
Rich
Common problems are
Iac valve
02 sensors
dpfe sensor
egr valve
maf sensor
throttle senser
Rich
I had the exact same problem with my 2000. Spent all kinds of money changing the MAF and the IAC. Finally after seeing the same problem on this site I change the lower intake gaskets. Fixed the problem and she runs perfect now. I'd bet its your lower intake gastkets leaking, but that just my opinion.
I had a local mech. do mine and it was about 120 bucks labor. I went to the ford dealer and bought the lower gaskets for about 20 dollars and got the upper gaskets for another 10. I figured I might as well change them also since its apart. You may want to call your ford dealer, If you exporer is the right year and low enough miles they might warrentee it.
FirstCarWasAFord
07-03-2016 06:12 PM
Bri...111
12-21-2015 09:41 PM
kswasko8896
03-04-2015 03:45 PM
jetskiman6969
12-21-2013 09:12 PM
F350Scott
18
05-12-2009 10:59 AM
