engine problems
Old Jan 17, 2004 | 12:57 AM
mikemhp's Avatar
mikemhp
Question engine problems
hello...
'97 f-250 5.4L triton, 79k miles...
check engine light came on 3 weeks ago. i took the truck to mechanic friend of mine who has the computer diag. sensor thingy.
codes that came up:P0133; P1131; P1000...
i have done the following: changed all the plugs, fuel filter, and 2 front O2 sensors. (upstream)
the problem persists. at low to mid rpm's, the engine runs like its at half power (sputters a little like its miss-firing or something.)
poor acceleration from stop, sometimes shaking from the engine/front of the truck. (mild).
at higher rpms, seems to run smoother until i floor it a little (passing or accellerating on freeway) then mild sputtering again. ALSO- when the sputtering occurs, i can hear mild clicking from the radio when on AM....
I'M GETTING BAFFELED!!!!
anyone have suggestions on what else might be going on?????
thanks for any help...
Old Jan 17, 2004 | 01:31 AM
LxMan1's Avatar
LxMan1
Hi and welcome to the forum
I would first try cleaning the mass-airflow sensor.
Also check for a vacuum leak. PCV hose is a common one.
Are you sure that the P1000 wasn't a P0100?
This would indicate a mass airflow malfunction which could be just because it is dirty.
Jimmy
Old Jan 17, 2004 | 08:24 PM
JustinH's Avatar
JustinH
right, clean the maf sensor and i would reset the computer.
I like to use electical parts cleaner, just spray it on the maf wires and let the dirt drip off, then blow it clean with a little canned air, don't touch the wires with a rag or something.
Old Sep 11, 2007 | 04:47 PM
maineoscarfish's Avatar
maineoscarfish
Question out of ideas
My 1995 Ford F250 was running fine yesterday morning by hte afternoon it kept bogging out. I gave it a full tune up and it did no good, now the exhaust smells like gas and the truck want start.
Old Sep 27, 2007 | 06:49 PM
crisper105's Avatar
crisper105
sounds like its your mass air flow sensor. its that little metal wire that hangs down in your air filter system. go and buy a cleaning spray from like canadian tire or something. spray the sensor and the throttle body to which the air transfers into. your truck should be running great. this is quite common with ford.
good luck!
Old Sep 29, 2007 | 10:20 AM
maineoscarfish
i fixed the problem it turned out to be the ignition coil but thanks for the help
wiwillis1980
Mar 22, 2020 07:41 AM
TheDoveNestVansion
3.8 & 4.2L V6
May 15, 2016 03:57 PM
03XL
1997 - 2003 F150
Mar 4, 2014 11:17 PM
swascott1981
1983 - 2012 Ranger & B-Series
Mar 21, 2012 05:02 AM
Drgslayr
Jul 16, 2009 02:49 PM
