EGR valve position sensor
on
1 Post
Re: EGR valve position sensor
Originally posted by JCastellaw
95 ford trowing a 334 egr position sensor. should I buy a egr valve?
You need to check this at the solenoid (sol pack near the coil)
look for proper activation of the sol when hot, idling and blipping the throttle.
then test if in fact vacuum is presented at the EGR, if so, test the EGR to hold vacuum, if so then test the EGP similar to a TPS to look for glitches.
on
1 Post
Originally posted by CrazyFordMan
i have been getting insuffisent Egr flow code. can you explain a little more in depth on how to check the solinoids and sensor and anything else i should check?
there is a set of 2-3 solenoids (I forget without a truck in front of me) right next to the ign coil on top of the motor, to the right of the intake runners/plenum.
Trace the vacuum line from the EGR to determine which one you want. This is a good time to see if it is rotten. back probe the 2 wire plug with a tester to see that yes indeed as you increase throttle off idle the solenoid does in fact change (I forget whether the ECM supplies voltage or ground - Im not near the shop or manuals right now) as you release the throttle the solenoid should go dead.
If you get the proper electrical signals all that means is that the ECM and/or its connections to those wires are intact and nothing more.
Problem is, the connections are not sealed like GM does - they corrode, pull the plug and using a tiny nail file clean the metal contact surfaces. This is perhaps 3/4s of the 'EGR valve problems' you will find on ford vehciles of any type using this system.
now, pull the vacuum line from the egr and hook to a vacuum gauge. At idle, no vacuum should be seen. Increase throttle and you should see vacuum, let go of throttle and it should disappear.
If you get this result then it proves the solenoid is working properly and that the wires are making contact with the terminals.
Next, apply a vacuum pump with gauge (avail for $40ish from autozone etc) to the EGR itself and test to see if in fact it can hold vacuum.
If it can, then this means the system works to this point - the EGR can in fact be acted upon by the ECM.
Next, backprobe the EVP and look for a varying voltage from the EGP as you apply vacuum via hand tool to the EGR. if you do see it, then it proves that the ECM is getting SOME feedback.
But note, at this point the EGR can still be sticking internally intermittently and the EVP output might be going out of range.
Here is where a few moments on the SBDS system will tell you if the EVP output matches the expected inputs.
Recently, in my own trucks case, my testing showed that the solenoid connections were corroded. I cleaned them, and replaced the solenoid anyways. Later, at intermittent times, I still got insufficient flow. Removal and inspection showed that the EGR was also sticking from time to time, feeling flush, I chose to replace the EGR and EVP. These parts are all avail at any advance/autozone and the sum should be <$100 which may or maynot be excessive to you.
* I might have given the EVP as EGP in another post - this is a typo
Blue Rebel
03-08-2012 10:45 AM
THE BLUE HEAP
29
02-12-2010 08:10 PM
DJdemon6696
05-08-2007 07:57 PM
