Power Steering Hose
Power Steering Hose
On each of the power steering hose, there are male fittings that go to either the pump or the rack-pinion unit.
I know that there are Teflon rings that go on these fittings. However, since the fitting can rotate rather freely on the metal tubing, I suspect that there must be one or two O-rings that seal between the fitting and the metal tubing. My question is whether or not one can replace these O-rings, and how?
Will someone shed some light on this matter, Aero? JT?
Thanks,
Copper
Thanks,
Copper
Copper,
According to my Chilton's manual, 91-97 models have fittings that have both the teflon outer seal and an O-ring inner seal around the hose/tube assembly. If you are experiencing a leak that is coming from between the fitting and the rack and pinion housing, then the teflon seal should be replaced. If the leak is coming from the center of the hose fitting (i.e. between the hose and the fitting) then the O-ring should be replaced.
Although my Chilton's includes information regarding changing the teflon seal, no mention is made on how to replace the O-ring. From what I can tell from the picture, there is a snap ring inside the fitting that secures it to the hose. How to release it and remove the fitting, I don't know.
Hope this helps. LOL
Ron
Ron
The connection between the fitting and the rack is OK. The leak I have is through the O-ring around the fitting/tube assembly like Ron a.k.a rlmdad described. Now the 35 dollar question is how to open it up so the inner O-ring can be replaced. I'm really cheap, so I would rather just replace the O-ring instead of spending 35 dollars for a new hose assembly. Ford really stuck it to us buyers, don't they?
Copper,
Like I said earlier, from the picture in my Chilton's there is a snap ring inside the fitting that holds it onto the hose assembly. Looking from the end of the hose can you see any way to release this snap ring? Is the end of the hose flared or could the fitting just be pressed on/off?
Just a thought.
Ron
Just a thought.
Ron
Thanks Ron. I see no way of removing anything from this assembly. So I bit the bullet, mortgaged my firstborn and bought a replacement hose from Autozone. It's made by Powercraft and carries a lifetime warranty, just so I don't have to worry about it leaking again after a couple of years.
Thanks again Ron and best regards,
Copper
Copper
on mine, when I push the fitting back with a twisting motion (not me... the fitting), it slides back far enough from the end of the pipe to reveal the inner o-ring. The teflon outer seal was rendered usless after unscrewing the fitting...used a liquid thread sealer with teflton that has done the trick so far.
clarkbre
04-16-2015 10:12 AM
money giver
1983 - 2012 Ranger & B-Series
03-12-2012 02:20 PM
jmbatlanta
04-26-2010 01:02 AM
