dana 44 solid axle gears work in dana 44 ifs???
If you don't know what a carrier break is, say so.
When you swap gears in a dana 44, you'll need a new carrier if you cross the 3.93 barrier. For example, if you have a 3.54 ratio now, and want to swap to a 4.10 ratio, you will need a new carrier. So in that case, it's not a straight swap.
If you're going from 3.09 (or whatever it is) to 3.54, you don't need a new carrier. The swap will work fine.
randys ring and pinion www.ring-pinion.com offers a thick 4.10 gearset for the d44 that allows you to use the low ratio case so you could keep ther same carrier
ok ...i got another bronco and i'm sellin it before i have time to do the solid axle swap i was gunna do but i already have the 9" with 3.50 gears installed...the ifs i have now has 273's in it so the 3.50's should fit in the 273 ifs front end?..
thanx for bein patient guys i just don't wanna pull the whole thing apart for nothin
Radster
12-05-2016 01:20 PM
F-1
10-03-2016 12:23 PM
sawmaned
Ford Truck Parts for Sale
07-31-2016 06:56 PM
