Another Gas Tank Question
Old 01-07-2004, 04:07 PM
ricky27330's Avatar
ricky27330
ricky27330 is offline
Can i put a set of gas tanks both front and rear out of a 93 in my 89 . I got a chance to get some good ones for a good price
let me know ok..............................thanxRICKY
Old 01-07-2004, 04:51 PM
larry derouin's Avatar
larry derouin
larry derouin is offline
If both trucks are the same bed size and cab size (ie: extended cab and short bed ......for example) the tanks should match up. If the 93 is a short bed and the 89 is a long bed with the same cab then the front one WILL NOT FIT.
The rear tank is interchangeable. You could use a bronco tank in the rear and do away with the front tank all together. you'd also have to move your spare tire somewhere else.
Measure TWICE all dimensions each tank, make sure they are same as current and then buy.
Old 01-07-2004, 05:54 PM
ftwfred's Avatar
ftwfred
ftwfred is offline
What is the capacity of the bronco tank??
I would love to have a larger rear (or front) tank.....
ftwfred
Old 01-08-2004, 11:15 PM
GypsyR's Avatar
GypsyR
GypsyR is offline
I'm not sure on that, in 80-83 the stock Bronco tank was 25 gallons, an a 32 gallon was an option. After 1984 a second size wasn't an option, I don't know which size they stuck with. One of the Bronco owners will know. Though I actually own an 89 it's never been filled up. Bought it cheap with a bad engine, once I get an engine in it I'm sure I'll discover how much it holds pretty quick.
iontkendall
12-21-2010 04:53 PM
breedo99
13
03-25-2010 09:07 PM
69 and 85
Iowa Chapter
12-29-2006 06:07 PM
JohnT
17
01-07-2006 11:21 PM
mohavi
Arizona Chapter
02-25-2004 09:17 PM
Quick Reply: Another Gas Tank Question
