Help ,door won't open?????
I have a 2000 ford f-250, 4x4, crewcab short box, power stroker,
and on friday a deer ran into the right side front fender and pushed it under the door less than a 1/4 inch!!!
Is there any way possible that I can move it forward just
enough to open the passenger door?? Any special tricks??
Thanks in advance.
Thanks in advance.
I have never done it on this truck before but.. I would start by pulling the front fender off looking around to see whats bent. Then pursuading the bent peice with a BFH and put the fender back on. If there is any bulking in the fender it may be a clue as to where the mounts can be persuaded.
99 F250SD EC 5.4L 3.73 285 BFG/ATs...
99 Expy EB 5.4L
99 Expy EB 5.4L
Bo and Luke Duke had that problem too. They just left the window down and jumped in.....lol
Sorry I just had to. If that fender is messed up anyway can you cut away the piece that's pushed under the door?
kc7dji
>stroker,
>tricks??
> Thanks in advance.
kc7dji
>stroker,
>tricks??
> Thanks in advance.
