Water leak in drivers floor board.
Does it have a moonroof?
TSB Article No. 03-11-10
BODY - WATER LEAK FROM ROOF OPENING PANEL - ROOF OPENING PANEL BINDS OR WILL NOT OPEN PROPERLY
NOISE - RATTLE FROM ROOF OPENING PANEL AREA
Publication Date: June 2, 2003
FORD: 2000-2003 EXPEDITION
2001-2003 F-150
2003 SUPER DUTY F SERIES
LINCOLN: 2000-2003 NAVIGATOR
ISSUE:
Some 2000-2003 Expedition/Navigator, 2001-2003 F-Series Under 8500, and 2003 F-Series over 8500 vehicles may exhibit a rattle from the roof opening panel (moonroof) area, a failure of the roof opening panel to open properly, or a water leak from the roof opening panel. This may be due to the water trough being separated from the trough guide on either side, as a result of a broken trough guide.
ACTION:
Check if the water trough is securely attached to the trough guide at each end. Check for damage to the lifter arm assemblies at the joint where the trough guide metal rods attach. Refer to the following Service Procedure for details.
2001-2003 F-150
ISSUE:
ACTION:
kcode
05-29-2014 09:44 AM
Ripcity
10-12-2013 09:45 AM
Howemd
05-27-2012 02:22 PM
vento
12-26-2003 10:45 PM
