As a side note I just saw a message from Ford regarding higher than stock wattage bulbs. They say to NOT use them as the wiring and connectors cant handle the extra amps that they draw. I've seen a few headlight connectors burned up now from higher wattage bulbs.
The silverstars are normal, stock wattages. I did the research before purchasing, and I must say, absolutely amazing the difference they made in my 97. The clear, crisp, white light they produce is far superior to the stock lights. I'd rate them a ten out of ten, and well worth the investment to anyone looking for better quality headlight bulbs.
