Sponsored by: Real Truck
Silverstar vs. OEM
Old Dec 11, 2006 | 01:51 PM
nut1605's Avatar
nut1605
Silverstar vs. OEM
I have a 2007 Super Duty, and I have seen some threads about people using the Silverstar bulbs. Do these make that much of a difference to warrant spending the $40+? I had a set of Silverstars on my 99 F-150 and was not impressed, but if they make a big difference on the Super Duty, I might look into it
Old Dec 11, 2006 | 02:28 PM
Lonewolftx's Avatar
Lonewolftx
Wink Nope . . .
Not that expensive see this thread . . .
https://www.ford-trucks.com/forums/5...r-friends.html
Or the further down in this listing as well . . .
Old Dec 11, 2006 | 02:42 PM
sofdchief's Avatar
sofdchief
silverstar
I just put a set of these in my '06 SD. I am not tremendously impressed, although they are a bit brighter than stock. Are they worth $40? No, I don't think so.....but then again, I got mine for $19.99 at Autozone.
Old Dec 11, 2006 | 04:21 PM
jeffwoehrle's Avatar
jeffwoehrle
Worth it. I noticed a huge difference.
Two thumbs up.
Old Dec 11, 2006 | 05:59 PM
JGRNAUT_7.3L's Avatar
JGRNAUT_7.3L
Smile
Did mine and love them, the fog lights are great now and the headlights are a little brighter but mainly did it for the fogs.
Old Dec 11, 2006 | 06:46 PM
slowmans's Avatar
slowmans
i have both the fog's and headlights , did notice a difference, i think they were worth it!
Old Dec 12, 2006 | 08:55 PM
jdadamsjr's Avatar
jdadamsjr
WHile I will do it as soon as the 9008's come out, an upgraded wiring harness will give you more bang for the buck !
Old Dec 12, 2006 | 09:17 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
silverstar bulbs are amazing. One problem though, in less than a year, my bulbs (both) have started doing this:
I rotated them 1/3 turn so hopefully it wont blow out. i guess they got so hot they just started sagging.
Old Dec 12, 2006 | 09:20 PM
Cuda444's Avatar
Cuda444
Strokin, do you have the upgraded harness on your truck?
Old Dec 12, 2006 | 09:36 PM
PowerstrokeJunkie
Yes, i do. bought it from summit before it was discontinued. That lets me run the diode in the blank passenger plug for the high and low beams together. So that might be generating some heat?
Old Dec 12, 2006 | 10:07 PM
Cuda444's Avatar
Cuda444
That'd be my guess... With both highs and lows on, you're running both filaments in the same volume of airspace inside the glass... It's a recipe for heat and melted bulbs. I'm not saying that's the definite cause, as this theory just popped into my head while reading, but my bulbs don't look like that and they are a least a year old...
Just my humble .02
Old Dec 12, 2006 | 10:37 PM
akford351's Avatar
akford351
Dp they really give out more light output or do they just look brighter?
I've tried a couple different coated bulbs, Nokya Arctic Whites & LUKS from Dfuser, and they actually seem to be worse than the stock bulbs. I even have the upgraded harness.
It really is a whiter light with a very very slight hint of blue but it seems less reflective overall and gives me slight eyestrain...
Old Dec 12, 2006 | 10:43 PM
Cuda444's Avatar
Cuda444
My silverstars are a whiter light than stock. I'd say they are brighter than stock. When I changed the bulbs, I did it in my garage, put one new bulb in, turned out the lights and turned them on to see if I could tell the difference. Sure enough, they were whiter and brighter... I shut the lights off, let them cool for a few, then swapped out the other bulb and haven't looked back. Don't be expecting an HID effect or anything, but they are brighter.
Old Dec 13, 2006 | 02:03 AM
ryaneverk2's Avatar
ryaneverk2
Upgraded headlight harness + upgraded bulbs will make a big difference in the output of the headlights.
I didn't care for the ultra-white look of the Silverstars, so I went with Xtravisions, which are the same bulb but w/out the blue coating on the ends like the Silverstars have.
Old Dec 13, 2006 | 06:14 AM
TheWiz427's Avatar
TheWiz427
Well worth it to me, Noticed a big difference right away.
