Silverstar bulbs, '03 F150
Anyone know if Sylvania has a Silverstar bulb to fit the '03 F150? If so, which one is it?
Yes. 9007
As a side note I just saw a message from Ford regarding higher than stock wattage bulbs. They say to NOT use them as the wiring and connectors cant handle the extra amps that they draw. I've seen a few headlight connectors burned up now from higher wattage bulbs.
Yes, but Silverstars are NOT higher wattage.
Are all Silverstars normal wattage or can you get higher output ones?
The silverstars are normal, stock wattages. I did the research before purchasing, and I must say, absolutely amazing the difference they made in my 97. The clear, crisp, white light they produce is far superior to the stock lights. I'd rate them a ten out of ten, and well worth the investment to anyone looking for better quality headlight bulbs.
Dube |
