Bed rails
Oh you mean these? I have a couple of OEM sets.....and they even have the plastic ***** that loosen up and slide adjust back and forth in the back side of the rail.
mic91F150 build up your post count to 25 then you can make and receive PM's (private messages are how sales are conducted on here and not in open forum).
Ck your visitor message box.
Dennis Carpenter lists the year coverage as 73-96. Also, if I recall correctly, the later E0TZ number is now a superseding part number for the D3TZ numbered rail kits.
Well I thought a 73-79 had more of a bed top edge curve, almost flat. I sat it on there with out the plastic gasket. But my set is not a good as I seem to remember.
Pitting on the one end and 2 small pits on the one middle. And then how in the heck did the one get bent, dang shop monkeys.
It mounted up ok, but failed my level straight edge test, but so did the one on ol silver. Mulling over some adjusted prices, you work over your PM ability.
#29
Site Guidelines - Ford-Trucks.com #6 so we will do it in PM's ok?
sounds good. Ill try to send you a PM now...
