on the front of an '85 f-150 do the lower studs that hold the spring cup in place take any lateral load? I know the lower half of the stud that's 3/4-10 holds the radius arm in place, but the 5/8-11 section, does it really ever have any forces exerted on it?
I need to machine a spacer for my air springs because I will be installing lift coils. Does anyone know what the diameter of the outside of the hex nut is? Mine is covered by the seating cup for the airspring, and I cannot measure it. If it's possible, a measurement from one corner of the nut to the oppisite corner would save me a lot of math. Thanks guys.
IIRC the nut is either 1-1/8 or 1-3/16 across flats.
To answer the original question, there's quite a lot of free play in the spring mounting at both ends, so the fasteners will see very little to zero shear loading above the beam.
