speedometer problems
Ok guys
I replaced the senor on the rear diff it seem to make the problem worse. I did have the rear diff rebuilt about a 2 months ago. So I am stuck!! I have read where it may be the token ring. Is there any way in troubleshooting the module. I used my snap on scanner and it did not pick any codes up. Another thing can I just to the PSOM (module) by itself of do I need to get the entire cluster, and is it really hard to change out?
Thanks
nmmountainguy
Thanks
nmmountainguy
If you look in the tech articles section of the website, you will find an article about chaning to a tach, that will show you how to dissassemble the cluster. You can buy the entire cluster from ford it's about 350 bucks, or you can get just the PSOM (programmable speedometer/odometer module) and swap it into ur truck (off ebay or junk yard). But you'll have to have it calibrated at a dealership for mileage and tire size so you'll have to check on how muhc that costs.
To check the tone ring...just take off the rear axle cover and check the teeth on the ring. If theres any wear or broken teeth it needs to be replaced. Has the needle bouced since they rebuilt it? It's possible they damaged it when re-assembling it.
rangerman321
1983 - 2012 Ranger & B-Series
09-28-2022 05:51 PM
jeffz
05-05-2011 11:25 AM
RobertNooy
03-30-2003 05:13 PM
