F-350 Emergency Brakes
1999 F-350 Super Duty 4x4 power stroke.
Just got a call from my dealer informing me that they have to replace both my rear brake pads and the entire emergency brake system. The pads were low from normal wear but the emergency brakes were evidently ruined from running the truck with the emergency brake on. My question is this: Are there two separate braking systems on a F-350? I thought the emergency brakes were part of the regular drum brakes in the rear.
Thank You
Thank You
Our trucks have 4 wheel discs. The (rear) e-brake is like a little drum setup. The rear rotors have a deeper hub section because it's really a small drum for the e-brake. If you took off the rotor you'd see an equally small set of shoes in there behind the hub. I say small compared to the truck there on, but our e-brakes are bigger that most cars rear brakes all together
It's pretty cool tho, i noticed it when i upgraded my brakes a couple months ago. I amagine they setup the e-brakes up like that because drum brakes hold much better in the rear, especially as an e-brake.
Hope that helps...
Nelson
Hope that helps...
Nelson
wolfmanagh,
Not sure about the E450s but i'm sure they compare to the F450s. That said, given the gvw or how much more the 450s can tow/carry i'm pretty sure they have large drum brakes in the rear. I mean the rear ends on those things are like the size of a rockwell. I wouldn't be surprised at all if the e-brakes on those trucks are on the driveshaft, 20% better braking there. The F250 -F350 Superduty have 4 wheel discs and have the internal mini-drum e-brakes as i explained above. If you still don't believe me take a rear tire off of that fine F250 you have there and take a look at the brakes...
Nelson
Nelson
03f250superduty5.4
1999 to 2016 Super Duty
18
04-18-2015 04:17 PM
Eddillard79
10-09-2014 07:15 PM
hivolt5.0
18
08-27-2008 05:09 PM
