Help! I need a diagram for the serpentine belt routing for a '91 ford f150 pickup. Does anyone know where to find one? The original label under the hood has been painted over. Thanks.
Are you sure there is no info? What motor/body style do you have? You should be able to look up any configuration so long as it's the same motor you have.
Hi again. I typed in 1991 f150 ford pickup... it came back and said there was no info for this vehicle. it is a 6 cyl. 2 wheel drive. Thanks for your help.
Originally posted by jayed Hi again. I typed in 1991 f150 ford pickup... it came back and said there was no info for this vehicle. it is a 6 cyl. 2 wheel drive. Thanks for your help.
The above post was my result in typing in 1991 F150, then F150 2WD (Regular Cab Styleside Long Box) OHV L6 (4.9L), the second one down, then to "Quickfind", then to "Belts".
Edit: Seems as though their links time out... Lets see if this works:
Hi again! Hope you got my last message.... I don't see it in the forum - I SAID I luv you guys, you are the best!!!! Really appreciate the help 'cuz I'm just a novice gal trying to get stuff going here. Bye the bye... I called the local ford dealer and he couldn't help me - said he didn't have a manual for one that old. What would I do without your help??????
