Pcm Fuse
Hi tigerj2 and welcome to FTE
You didnt pick a very good fuse to have a problem with
The #24 fuse protects the power circuit to almost every engine control sensor, the fuel pump relay, injectors etc.
I would probably start by checking the wiring harness that goes down the back of the engine to the transmission and see if it's rubbed through anywhere. Also take a look at the main harness on the outside of the frame behind the driver's front wheel.
Maybe HomerWinzlow or one of the other Ford techs here has seen this problem before.
rolltide3006
09-21-2012 06:44 PM
