351M plug gap too big?
Old 10-20-2003, 12:18 PM
MSC's Avatar
MSC
MSC is offline
351M Plug Gap?
I've got a 77 351M in my 74 F100. The distributor I think is out of the original 360, it's a breaker type dist. The plug gap is .044 for the 351M. Is this to big for the breaker type dist? Should I decrease it or leave it alone?
Mark C.
Old 10-20-2003, 04:09 PM
MSC's Avatar
MSC
MSC is offline
I've got a 77 351m in my 74 F100. The distributor I think is out of the original 360, it's a breaker type dist. The plug gap is .044 for the 351M. Is this to big for the breaker type dist? Should I decrease it or leave it alone?
Mark C.
Old 10-20-2003, 08:38 PM
thelonerangerxlt's Avatar
thelonerangerxlt
thelonerangerxlt is offline
Mark, it depends on which coil you have on it. If it's the points type coil, the plug gap should be .035". If you're using the DuraSpark coil with the clip-on terminals, the plug gap should be .044". It's the energy output of the coil that determines the sparkplug gap.
Old 10-20-2003, 10:39 PM
MSC's Avatar
MSC
MSC is offline
It's has an Acell Super Coil on it. I'm guessing that .044 is OK then. It runs fine gapped at .044, but I was just wandering about it.
Thanks
Mark C.
Old 10-21-2003, 09:24 AM
thelonerangerxlt
Yep, .044" is fine with the Accel coil. It would probably take gaps up to about .050" without misfires. (Some people even go up to .055" with a performance coil.)
A Pertronix Breakerless kit would be an easy upgrade for that distributor. You'd never have to change and set points again.....
Johno.h
15
08-18-2016 03:45 AM
Coastal68
29
09-30-2015 07:59 PM
hardy541
15
12-27-2014 12:31 PM
crakerjack51
02-23-2008 04:33 PM
Binder Guy
05-09-2004 01:35 PM
Quick Reply: 351M plug gap too big?
