trailer light problems
Old 10-13-2003, 02:19 PM
bluemoose89's Avatar
bluemoose89
bluemoose89 is offline
i am having trouble wityh the trailer lights on my 99 psd i have hooked up to 2 diffrent trailers sometimes they dont work at all and other times the blinkers dont work nor the brake lights but the running lights work...and suggestions?
Old 12-23-2003, 04:03 PM
'98 Ford F150's Avatar
'98 Ford F150
'98 Ford F150 is offline
I am having the same problem. The lights on the truck work fine. I tested the plug and am not getting anything there. Have you corrected your problem yet?
Old 12-23-2003, 05:43 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Are those trailer plugs Matched to the *Standard Positions* per the connector?
http://mil1ion.clubfte.com/Trailerwiring.jpg
I have my trailer connector set special for me & MY truck.
I also have pigtails that converts it to standard wiring.
If someone tries to steal it ,they will noticed by other drivers.
The other thing is I have the continuous power to trailer actually hooked up to the trailer brakes.
Old 12-23-2003, 06:29 PM
'98 Ford F150
Mil1ion,
Mine look exactly like the photo, (factory install). The trailer lights have worked for years. I hooked up yesterday and had nothing but taillights!! I have tested the harness on the truck and it seems o.k. (continuity check). I hooked the trailer to another vehicle and it works perfectly.
Thanks,
Ken
Old 12-23-2003, 07:56 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Possible corrosion at the Truck connection terminals ?
Old 12-24-2003, 08:32 AM
'98 Ford F150
I disconnected the harness and checked the terminals. They were in great shape.
In searching previous posts, I notice that this is not that uncommon an occurrence. The posts that I have reviewed however do not give explanations as to how the problem was solved. I cannot directly e-mail anyone because I have not been a member long enough and do not have enough posts. Frustrating!!
Thanks,
Ken
Old 12-24-2003, 10:29 PM
'98 Ford F150
WhipsnHorses directed me to a third fuse box that was not mentioned in my owners manual. 20 amp mini fuse blown. Trailer lights operational once again. Thanks so much for the help.
Ken
Old 12-25-2003, 03:12 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Yes frustrating it is when people don't follow up thread with the end result being positive or negative.
Mostly it is because people don't go ( too lazy) find that original thread to update.
Glad you got it fixed
Old 12-25-2003, 08:07 AM
'98 Ford F150
Thanks for the note Dennis. I guess the third fuse box wasn't detailed in the owners manual because the towing package was an option(???). Anyway,... lesson learned...
Merry Christmas,
Ken
kirkharrod
06-06-2017 12:53 AM
Leichardti
1999 to 2016 Super Duty
05-26-2015 08:30 PM
silentrunning
02-24-2012 06:20 AM
2006SDpower
07-26-2011 11:51 AM
Deerslayinrenek
06-25-2010 03:58 PM
Quick Reply: trailer light problems
