i am having trouble wityh the trailer lights on my 99 psd i have hooked up to 2 diffrent trailers sometimes they dont work at all and other times the blinkers dont work nor the brake lights but the running lights work...and suggestions?
I am having the same problem. The lights on the truck work fine. I tested the plug and am not getting anything there. Have you corrected your problem yet?
Mil1ion,
Mine look exactly like the photo, (factory install). The trailer lights have worked for years. I hooked up yesterday and had nothing but taillights!! I have tested the harness on the truck and it seems o.k. (continuity check). I hooked the trailer to another vehicle and it works perfectly.
Thanks,
Ken
I disconnected the harness and checked the terminals. They were in great shape.
In searching previous posts, I notice that this is not that uncommon an occurrence. The posts that I have reviewed however do not give explanations as to how the problem was solved. I cannot directly e-mail anyone because I have not been a member long enough and do not have enough posts. Frustrating!!
Thanks,
Ken
WhipsnHorses directed me to a third fuse box that was not mentioned in my owners manual. 20 amp mini fuse blown. Trailer lights operational once again. Thanks so much for the help.
Ken
Thanks for the note Dennis. I guess the third fuse box wasn't detailed in the owners manual because the towing package was an option(???). Anyway,... lesson learned...
Merry Christmas,
Ken
