Air Injection Troubles
Old 03-12-2001, 05:44 PM
KevinT's Avatar
KevinT
KevinT is offline
Old 03-16-2001, 10:42 PM
falonge's Avatar
falonge
falonge is offline
I have a 1996 F150 with the 4.9 Liter engine. The smog pump was getting noisy, so I replaced it with a new one. About 75 miles after replacing the smog pump, I recieved a check engine light. I read the code and it came up P0411 which is "Secondary air injection - incorrect flow". I figured that the new smog pump was the problem. So I took the pump back and exchanged it for another one. Shortly thereafter the code returned.
I have checked all connections to the smog pump and everything in the vicinity. I cleaned the smog pump air intake filter as well. I consulted my local Ford dealer and they suggested I put a vacuum on the diverter valve and see if it is functioning. I have done this and while I do hear movement internally, I have no way of being certain if it is operating 100%.
I can clear the code and it generally will not come back on during stop-and-go driving, but highway driving will bring it back. The code everytime has been P0411. I now have over 500 miles on the smog pump, so I know it is not a break-in issue.
Any suggestions would be appreciated.
Thanks.
Old 03-16-2001, 11:50 PM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
Check all the vacuum lines first . Sorry , I dont have any diagnostic routines to help you out .
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Air Injection Troubles
