428 head casting numbers
Old 09-18-2003, 11:59 AM
anotherF150's Avatar
anotherF150
anotherF150 is offline
I am looking for a set of 428 heads and think that I have found some but am not sure. I have c7e5 and c8ae they are out af a couple of T-Birds and need the heads to complete a build. If these arent 428 # can some one help with a few # that are or would be 428 heads. Any help would be appreciated.
Old 09-18-2003, 01:42 PM
BB's Avatar
BB
BB is offline
There wasn't a unique head for the 428, they just used the 390 head. Which 390 head they used depends on the year.
Barry
Old 09-18-2003, 10:03 PM
anotherF150
they did use a different head casting number for 428 in 67 and 68 I would just like a another party for reassuance that they are 428 heads.
Old 09-18-2003, 11:20 PM
BB's Avatar
BB
BB is offline
Well ok, I'll go with it. Is there anything else after the C8AE like a letter, maybe on the other side of the spark plug hole? Or does it look like something was covered up right after the E?
I've never heard of a C7E5, is that number in the same place as the other head? Could you check the number again?
Barry
Old 09-19-2003, 12:54 PM
BB's Avatar
BB
BB is offline
While you’re looking, here’s a little more info. The Ford Car Service Specifications says the ’66 352, 390, 410 and 428 heads were 73.1 – 76.1cc. Here’s a pic of a C6 head, note the “D” shape and the sharp corners on the flat side.
The ’67 390, 410 and 428 heads were 71.2 – 74.2cc. Here’s a pic of the C7 head, note it still has a “D” shape but shallower and the corners are rounded on the flat side.
The ’68 390 and 428 heads were 67.1 – 70.1cc. Here’s a pic of the C8 head, note the new kidney bean shape and the flat side is at an angle.
Old 09-20-2003, 03:24 PM
anotherF150
Thare wasn't any other markings but acording to ASE the c8ae is a 428 head in 68 and the other head that you havent herd of came out of a 2 on truck probibly a FT.
Old 09-20-2003, 10:47 PM
BB's Avatar
BB
BB is offline
C7E5 is interesting, it doesn't match the alphanumeric sequence. FT's usually have something like C7TE.
Anyway about the 428's, When I first started taking an interest in FE's all the '68 428's I saw had C8AE-A heads. Then I started to see C8AE-H heads too but thought maybe they're from a valve job. That was dismissed when I found a virgin 428PI with H heads and have later read about them on a FE board. Speaking of boards, I also have read on a Galaxie board that C8AE heads were 428's too and were a little smaller, good for 1/2 point. Don't know if the A head was as tight, this is all stuff I have read so I don't really like spreading it around like gospel. Maybe you could pull those heads and let us know, they can't be all that bad.
Barry
firsttofight11b
38
09-25-2017 10:53 AM
tracytruelove
49
08-08-2013 11:11 AM
1972RedNeck
06-01-2012 07:17 PM
rodriguezfords
16
01-10-2010 07:43 PM
highboy 74
20
12-02-2003 06:31 AM
Quick Reply: 428 head casting numbers
